Themis 2 (Motion Deblur)
Restore clarity to fast-moving footage
Model Overview
Themis 2 reduces blur caused by rapid camera movement or fast-moving subjects. It recovers clarity and sharpness while avoiding the harsh edges and artifacts aggressive sharpening introduces.
It is best suited to action footage, handheld shots, and fast motion where traditional sharpening can't recover lost detail.
Best Use Cases
Action footage. Recover detail in fast motion.
Handheld shots. Reduce blur from camera shake.
Sports. Sharper fast-moving subjects.
Legibility. Make text and details in motion readable.
Before upscaling. Deblur first, then upscale.
Endpoint
https://api.topazlabs.com/video/
https://api.topazlabs.com/video/express
Model Parameters
Model parameters go inside the filter object in filters.
Themis 2 uses the Precision filter parameter set. Every parameter below is optional except model; any value you don't send is estimated automatically.
model
string
Required
"thm-2"
videoType
string
Optional
"Progressive", "Interlaced", "ProgressiveInterlaced"
Frame/field type of the source.
auto
string
Optional
"Auto", "Manual", "Relative"
Parameter mode. Auto estimates every value, Relative nudges the estimated values by the amounts you send, Manual uses your values as-is.
fieldOrder
string
Optional
"TopFirst", "BottomFirst", "Auto"
Field order for interlaced sources.
focusFixLevel
string
Optional
"None", "Normal", "Strong"
Downscales the input for stronger correction of blurred subjects.
compression
decimal
Optional
-1.0 to 1.0
Strength of compression artifact recovery.
details
decimal
Optional
-1.0 to 1.0
Amount of detail reconstruction.
prenoise
decimal
Optional
0.0 to 0.1
Adds noise to the input to reduce over-smoothing.
noise
decimal
Optional
-1.0 to 1.0
Amount of noise reduction.
halo
decimal
Optional
-1.0 to 1.0
Amount of halo reduction.
preblur
decimal
Optional
-1.0 to 1.0
Anti-aliasing and deblurring strength.
blur
decimal
Optional
-1.0 to 1.0
Amount of sharpening applied.
grain
decimal
Optional
0.0 to 0.1
Adds grain after processing.
grainSigma
decimal
Optional
0.0 to 1.0
Grain granularity.
grainSize
decimal
Optional
0.0 to 5.0
Size of generated grain.
grainType
string
Optional
"silver_rich", "gaussian", "grey"
Type of grain.
recoverOriginalDetailValue
decimal
Optional
0.0 to 1.0
Reintroduces source detail into the output.
For the shared video pipeline parameters (source, output, encoders and profiles), reference the Denoising intent page. The full set of accepted parameters is also available in our API Reference page.
For request parameters shared by every video model (source, output, destination, and notifications), see Request Parameters. The full schema is also available in our API Reference page.
Model Pricing
1080p Output
5 s
10 s
30 s
3
4
8
1 min
6
8
15
5 min
29
37
73
10 min
58
73
145
4K Output
5 s
5
10 s
4
5
10
30 s
12
15
29
1 min
24
29
58
5 min
116
145
290
10 min
232
290
580
Example Request
Limitations
Themis 2 doesn't upscale.
Helpful Resources
Last updated
Was this helpful?
