Chronos Fast
Faster Chronos for time-sensitive work
Model Overview
Chronos Fast prioritizes processing speed over maximum precision, at about half the cost of Chronos.
It is a practical option for longer sequences and time-sensitive workflows. For the most precise results, use Chronos.
Best Use Cases
Long sequences. Faster processing for long footage.
Time-sensitive work. Quick frame rate conversion.
High-volume conversion. Lower cost for large batches.
Previews. Test settings before a Chronos pass.
Simple motion. Fast results on straightforward footage.
Endpoint
https://api.topazlabs.com/video/
https://api.topazlabs.com/video/express
Model Parameters
Model parameters go inside the filter object in filters.
model
string
Required
"chf-3"
slowmo
integer
Optional
1 to 16
Slow-motion factor. 2 doubles the duration, 4 quadruples it, and so on.
fps
decimal
Optional
15 to 240
Target output frame rate. Required unless output.frameRate is set (POST /video/ always requires output.frameRate). If both are set, the higher one is used.
duplicate
boolean
Optional
Detects and replaces duplicate frames in the source.
duplicateThreshold
decimal
Optional
0.001 to 0.1
Sensitivity for duplicate-frame detection.
For request parameters shared by every video model (source, output, destination, and notifications), see Request Parameters. The full schema is also available in our API Reference page.
Model Pricing
Chronos Fast is priced per gigapixel (GP) of newly generated frames: 1 credit per GP. Source frames passed through unchanged aren't charged.
This is about half the cost of Chronos.
Example Request
Limitations
Frame interpolation models don't upscale.
Helpful Resources
Last updated
Was this helpful?
