Apollo Fast
Faster Apollo for simpler motion
Model Overview
Apollo Fast is a faster version of Apollo for simpler motion, offering quicker turnaround for retiming workflows at about half the cost.
For non-linear or more complex motion, use Apollo.
Best Use Cases
Simple motion. Fast retiming of straightforward movement.
Quick turnaround. Faster processing for tight deadlines.
High-volume retiming. Lower cost for large batches.
Previews. Test slow-motion settings before an Apollo pass.
Frame rate conversion. Fast conversion for simple footage.
Endpoint
https://api.topazlabs.com/video/
https://api.topazlabs.com/video/express
Model Parameters
Model parameters go inside the filter object in filters.
model
string
Required
"apf-2"
slowmo
integer
Optional
1 to 16
Slow-motion factor. 2 doubles the duration, 4 quadruples it, and so on.
fps
decimal
Optional
15 to 240
Target output frame rate. Required unless output.frameRate is set (POST /video/ always requires output.frameRate). If both are set, the higher one is used.
duplicate
boolean
Optional
Detects and replaces duplicate frames in the source.
duplicateThreshold
decimal
Optional
0.001 to 0.1
Sensitivity for duplicate-frame detection.
For request parameters shared by every video model (source, output, destination, and notifications), see Request Parameters. The full schema is also available in our API Reference page.
Model Pricing
Apollo Fast is priced per gigapixel (GP) of newly generated frames: 2 credit per GP. Source frames passed through unchanged aren't charged.
This is about half the cost of Apollo.
Example Request
Limitations
Frame interpolation models don't upscale.
Helpful Resources
Last updated
Was this helpful?
