Background Removal
Remove backgrounds from images
Model Overview
Background Removal is a high-quality image segmentation model designed to isolate subjects from their background with precise, production-ready edge handling.
It delivers clean extractions across a wide range of photography scenarios, preserving fine details such as hair, soft edges, and semi-transparent elements. Well suited for both creative and high-volume image workflows, including product photography and e-commerce, flexible mask parameters enable further refinement for compositing, design, or downstream use.
Best Use Cases
E-commerce product photography. Cut products onto transparent or white backgrounds for marketplace listings with consistent, clean edges.
Portraits and people. Isolate subjects with natural hair and clothing edges for headshots, ads, and profile images.
High-volume cutout pipelines. Process large batches of user-submitted or supplier images with the same result every time.
Design and marketing assets. Produce cutouts and masks for ads, thumbnails, and layered artwork.
Fine and translucent detail. Handle fur, glass, veils, and soft edges that need a true alpha rather than a hard mask.
Endpoint
https://api.topazlabs.com/image/v1/matting/async
Model Parameters
model
string
Required
"RemoveBG"
output_type
string
Optional
Default: rgba
"rgba", "alpha"
rgba returns the subject on a transparent background as an RGBA PNG. alpha returns a mask of the subject.
For request parameters shared by every image endpoint, see Request Parameters. The full schema is also available in our API Reference page.
Model Pricing
Background Removal costs 1 credit per every 24 MP of generated output. The below table includes a list of common output resolutions with associated credit costs.
640×480
VGA
0.31
1280×720
720p
0.92
1920×1080
1080p
2.07
2560×1440
1440p
3.69
3840×2160
4K UHD
8.29
4000×3000
12 MP phone
12.00
5472×3648
20 MP camera
19.96
6000×4000
24 MP camera
24.00
7680×4320
8K UHD
33.18
7952×5304
42 MP camera
42.18
8192×5464
45 MP camera
44.76
9504×6336
61 MP camera
60.22
3
11648×8736
100 MP medium format
101.76
5
Credits
Example Request
Limitations
This model accepts up to 256 MP input and output. Output is always PNG.
Helpful Resources
Last updated
Was this helpful?
