> For the complete documentation index, see [llms.txt](https://developer.topazlabs.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://developer.topazlabs.com/image-models/color-and-lighting/adjust-lighting-1.md). Agents can also search and read this documentation through its [MCP server](https://developer.topazlabs.com/~gitbook/mcp).
# Adjust Lighting 1
Deprecated. Replaced by Adjust Lighting 2.
{% hint style="warning" %}
**Adjust Lighting 1 is deprecated** and will be retired no sooner than January 1, 2027. Use Adjust Lighting 2 instead. See Model Deprecations for migration steps.
{% endhint %}
### Model Overview
**Adjust Lighting 1** is an earlier version of our lighting correction model. It is deprecated and no longer recommended for new integrations.
Use **Adjust Lighting 2** instead.
### Endpoint
`https://api.topazlabs.com/image/v1/lighting/async`
### Model Parameters
| Parameter | Type     | Required / Default | Accepted values | Description |
| `model`   | `string` | Required           | `"Adjust"`      | —           |
For request parameters shared by every image endpoint, see Request Parameters. The full schema is also available in our API Reference page.
### Model Pricing
**Adjust Lighting 1** costs 1 credit per every 24 MP of generated output. The below table includes a list of common output resolutions with associated credit costs.
| Resolution | Typical Source       | Output MP | Credits |
| 640×480    | VGA                  | 0.31      | 1       |
| 1280×720   | 720p                 | 0.92      | 1       |
| 1920×1080  | 1080p                | 2.07      | 1       |
| 2560×1440  | 1440p                | 3.69      | 1       |
| 3840×2160  | 4K UHD               | 8.29      | 1       |
| 4000×3000  | 12 MP phone          | 12.00     | 1       |
| 5472×3648  | 20 MP camera         | 19.96     | 1       |
| 6000×4000  | 24 MP camera         | 24.00     | 1       |
| 7680×4320  | 8K UHD               | 33.18     | 2       |
| 7952×5304  | 42 MP camera         | 42.18     | 2       |
| 8192×5464  | 45 MP camera         | 44.76     | 2       |
| 9504×6336  | 61 MP camera         | 60.22     | 3       |
| 11648×8736 | 100 MP medium format | 101.76    | 5       |
| Output MP | 1 | 4 | 8 | 16 | 24 | 32 | 40 |
| Credits   | 1 | 1 | 1 | 1  | 1  | 2  | 2  |
{% hint style="info" %}
For more accurate credit cost estimates, we recommend using our [Credit Calculator](https://developer.topazlabs.com/credit-calculator).
{% endhint %}
### Example Request
{% tabs %}
{% tab title="cURL" %}
```bash
curl -X POST "https://api.topazlabs.com/image/v1/lighting/async" \
  -H "X-API-Key: $TOPAZ_API_KEY" \
  -F "image=@photo.jpg" \
  -F "model=Adjust"
{% endtab %}
{% tab title="JavaScript" %}
```javascript
import fs from 'fs';
import FormData from 'form-data';
const form = new FormData();
form.append("image", fs.createReadStream("photo.jpg"));
form.append("model", "Adjust");
const response = await fetch("https://api.topazlabs.com/image/v1/lighting/async", {
  method: 'POST',
  headers: {
    'X-API-Key': process.env.TOPAZ_API_KEY,
    ...form.getHeaders(),
  body: form,
if (!response.ok) {
  throw new Error(`Request failed: ${response.status} ${await response.text()}`);
console.log(await response.json());
{% endtab %}
{% tab title="Python" %}
```python
import os
import requests
with open("photo.jpg", "rb") as image:
    response = requests.post(
        headers={"X-API-Key": os.environ["TOPAZ_API_KEY"]},
        files={"image": image},
        data={
            "model": "Adjust"
response.raise_for_status()
print(response.json())
{% endtab %}
{% endtabs %}
### Migrating to Adjust Lighting 2
1. Keep the `/image/v1/lighting/async` endpoint and set `model` to `Adjust V2`.
2. Pricing is unchanged at 24 MP per credit.
### Limitations
This model accepts up to 256 MP input and output.
### Helpful Resources
<table data-view="cards"><thead><tr><th></th><th></th><th></th><th data-hidden data-card-target data-type="content-ref"></th></tr></thead><tbody><tr><td><i class="fa-play">:play:</i></td><td><h4>Image Quickstart</h4></td><td>Quickly get started with our Image API.</td><td></td></tr><tr><td><i class="fa-file-brackets-curly">:file-brackets-curly:</i></td><td><h4>API Reference</h4></td><td>View our API reference to view the entire schema.</td><td><a href="https://playground.topazlabs.com/">https://playground.topazlabs.com/</a></td></tr><tr><td><i class="fa-square-root-variable">:square-root-variable:</i></td><td><h4>Model Pricing</h4></td><td>Learn how we price our models.</td><td></td></tr></tbody></table>
# Agent Instructions
This documentation is published with GitBook. GitBook is the documentation platform designed so that both humans and AI agents can read, navigate, and reason over technical content effectively. Learn more at gitbook.com.
## Querying This Documentation
If you need additional information that is not directly available in this page, you can query the documentation by asking a question.
Perform an HTTP GET request on the following URL with the `ask` and `goal` query parameters:
GET https://developer.topazlabs.com/image-models/color-and-lighting/adjust-lighting-1.md?ask=<question>&goal=<user_goal>
`ask` is the immediate question: it should be specific, self-contained, and written in natural language.
`goal` is what the user is ultimately trying to achieve, the reason they need the answer. Sharing it helps GitBook give you a better, more relevant answer. A goal is most helpful when it describes the outcome the user wants rather than restating the question. For example, with `ask=how do I create an API token`, a goal like `automate deployments from our CI pipeline` lets GitBook tailor the answer to that use case.
The response will contain a direct answer to the question and relevant excerpts and sources from the documentation.
Use this mechanism when the answer is not explicitly present in the current page, you need clarification or additional context, or you want to retrieve related documentation sections.
